2024 KTM 690 Enduro R.
2024 KTM 690 Enduro R. (KTM/)
The original 690 Enduro R came out for the 2008 model year, and after all these years is still unique in the dual sport class. This single-cylinder dual sport can serve many purposes from lightweight ADV to heavyweight enduro, which gives it a ton of versatility. It also has more than enough power to be a great streetbike.
Its 693cc SOHC single is shared with no less than five other models including its Supermoto sibling under the KTM banner. It is liquid-cooled, has electric starting, fuel injection, and features ride-by-wire throttle, which allows multiple ride modes. It also has lean-sensitive ABS and traction control.
A steel-trellis frame and composite subframe with integrated fuel tank anchor the chassis. Suspension consists of a WP 48mm Xplor fork with 9.8 inches of travel in the front and a linked WP shock with identical travel. Wheels measure 21 inches in front and 18 inches at the rear with 90/90-21 and 140/80-18 rubber, respectively. Brembo brakes with Bosch ABS handle braking duty.
The 2024 KTM 690 Enduro R is $12,999 in the single orange and black color.
  • <a href="https://www.cycleworld.com/honda/xr650l/"><b>Honda XR650L, $6,999</b></a>
  • <a href="https://www.cycleworld.com/kawasaki/klr650/"><b>Kawasaki KLR650, starting at $6,899</b></a>
  • <b>2025 </b><a href="https://www.cycleworld.com/story/buyers-guide/2020-suzuki-dr650s/"><b>Suzuki DR650S, $7,199</b></a>
  • <a href="https://www.cycleworld.com/husqvarna/701-enduro/"><b>Husqvarna 701 Enduro, $12,999</b></a>
  • <a href="https://www.cycleworld.com/story/motorcycle-news/gasgas-es-700-first-look-2023/"><b>GasGas ES 700, $12,699</b></a>
News and Reviews
  • <a href="https://www.cycleworld.com/ktm-unveils-690-enduro-r-at-eicma/"><b>KTM 690 Enduro R First Look</b></a>
2024 KTM 690 Enduro R Enduro Claimed Specs
MSRP: $12,999
Engine: SOHC, liquid-cooled single; 4 valves
Displacement: 693cc
Bore x Stroke: 105.0 x 80.0mm
Compression Ratio: N/A
Fuel System: Keihin EFI w/ 50mm throttle body; ride-by-wire
Clutch: Wet, multiplate slipper; hydraulic operation
Frame: Chromoly steel trellis
Front Suspension: WP 48mm Xplor inverted fork, compression and rebound adjustable; 9.8 in. travel
Rear Suspension: WP linked monoshock, fully adjustable; 9.8 in. travel
Front Brake: 2-piston Brembo caliper, 300mm disc w/ ABS
Rear Brake: 1-piston Brembo caliper, 240mm disc w/ ABS
Wheels, Front/Rear: Spoked; 21 in./18 in.
Tires, Front/Rear: 90/90-21 / 140/80-18
Rake/Trail: 27.7°/NA
Wheelbase: 59.3 in.
Ground Clearance: 10.6 in.
Seat Height: 36.4 in.
Fuel Capacity: 3.6 gal.
Wet Weight: 322 lb.
Contact: ktm.com
