Admin Posted August 9, 2024 Posted August 9, 2024 2024 Kawasaki Ninja 650. (Kawasaki/) Overview Kawasaki’s Ninja 650 offers the look of a traditional supersport, but with the practicality of a parallel twin and neutral ergonomics. A balance between performance and functionality, the Ninja 650 is capable of carving up a mountain pass or spinning laps at the track, but is equally enjoyable commuting to work. The 2024 Kawasaki Ninja 650 features a 649cc liquid-cooled parallel twin with dual 36mm Keihin throttle bodies, a six-speed transmission, and a slipper/assist clutch. Rider aids are limited to ABS and switchable traction control, which can be adjusted via the 4.3-inch color TFT display. The Ninja 650′s sporty styling is inspired by the track-focused Ninja ZX-6R. Chassis components consist of a high-tensile steel trellis frame, a nonadjustable 41mm telescopic fork, and a spring-preload adjustable shock. The braking system features dual twin-piston calipers with 300mm rotors up front, and a single-piston caliper with a 220mm disc at the rear. Wheel sizes are 17 inches and the tire dimensions are 120/70-17 front and 160/60-17 rear. Updates to the 649cc mill in 2017 aimed to increase low-end and midrange power. Qualities suitable for a street-going sportbike rather than a high-revving trackday weapon. Handling characteristics are sporty enough for spirited riding, but the Ninja 650 isn’t so committed that the ride quality suffers during casual commuter miles. 2024 Kawasaki Ninja 650 KRT Edition ABS. (Kawasaki/) Pricing and Variants The 2024 Kawasaki Ninja 650 is available in Metallic Matte Graphenesteel Gray/Ebony (non-ABS only) for $8,299. Kawasaki also offers the Ninja 650 in Metallic Matte Dark Gray/Metallic Spark Black/Metallic Flat Spark Black or Metallic Matte Covert Green/Metallic Spark Black/Pearl Sand Khaki for $8,499 (non-ABS) or $8,899 (ABS). And for those who want race-inspired graphics, Kawasaki offers the Ninja 650 KRT Edition ABS for $8,899. 2024 Kawasaki Ninja 650. (Kawasaki/) Competition <a href="https://www.cycleworld.com/motorcycle-reviews/suzuki-gsx-8r-first-ride/"><b>Suzuki GSX-8R, $9,439</b></a> <a href="https://www.cycleworld.com/yamaha/yzf-r7/"><b>Yamaha YZF-R7, $9,199</b></a> <a href="https://www.cycleworld.com/honda/cbr650r/"><b>Honda CBR650R, $9,899</b></a> <a href="https://www.cycleworld.com/triumph/daytona-660/"><b>Triumph Daytona 660, $9,195</b></a> News and Reviews <a href="https://www.cycleworld.com/sport-rider/2017-kawasaki-ninja-650-ride-review/"><b>2017 Kawasaki Ninja 650 Ride Review</b></a> <a href="https://www.cycleworld.com/story/motorcycle-reviews/kawasaki-ninja-650/"><b>2020 Kawasaki Ninja 650 First Ride</b></a> <a href="https://www.cycleworld.com/2017-kawasaki-ninja-650-sportbike-motorcycle-review/"><b>2017 Kawasaki Ninja 650 - First Ride Review</b></a> 2024 Kawasaki Ninja 650 Claimed Specs MSRP: $8,299 / $8,499–$8,899 (ABS) Engine: DOHC, liquid-cooled, 4-stroke parallel twin Displacement: 649cc Bore x Stroke: 83.0 x 60.0mm Compression Ratio: 10.8:1 Transmission/Final Drive: 6-speed/chain Fuel System: DFI w/ dual 36mm Keihin throttle bodies; ride-by-wire Clutch: Wet, multiplate; cable operation Frame: High-tensile steel trellis Front Suspension: 41mm hydraulic telescopic fork; 4.9 in. travel Rear Suspension: Horizontal back-link shock, preload adjustable; 5.1 in. travel Front Brake: 2-piston calipers, 300mm discs (w/ ABS) Rear Brake: 1-piston caliper, 220mm disc (w/ ABS) Wheels, Front/Rear: Cast spoked; 17 in./17 in. Tires, Front/Rear: 120/70-17 / 160/60-17 Rake/Trail: 24.0°/3.9 in. Wheelbase: 55.5 in. Ground Clearance: 5.1 in. Seat Height: 31.1 in. Fuel Capacity: 4.0 gal. Wet Weight: 421 lb. / 423 lb. (ABS) Contact: kawasaki.com View the full article Quote
