2025 Triumph Speed Twin 1200 & Speed Twin 1200 RS Review
I have a 2020 model Speed Twin 1200 and have owned it for the past four years and done some 20,000 miles on the bike. I use this bike for everyday riding, ride outs and touring.
Me and my Speed Twin 1200 touring in Spain
I had this bike on loan from Triumph UK to ride and review and I was so taken with the bike that when it went back I asked if I could buy it at the end of the season when the press bikes come up for sale.
So, when Triumph announced the new 2025 models for the Speed Twin namely, the 1200 and 1200 RS, I was eager to have these on loan to review. I have had both models for a couple of weeks each, back to back.
The new 1200’s have evolved with their raked fuel tank, front cutouts, brushed aluminium throttle body covers in sculpted side panels inside a slim rear frame. There are machined cooling fins on the cylinder head and finned header roses.
I was really interested to see what the differences were (apart from the extra £2,000 price tag for the RS) with my bike and if I would be tempted to trade my bike in for one.
Let’s see, shall we….
A Few Specs for you:
Speed Twin 1200Speed Twin 1200 RS
PriceFrom £12,495From £14,495
Colours Aluminium Silver; Sapphire Black/Crystal White; Sapphire Black/Carnival RedSapphire Black; Sapphire Black/Baja Orange
Max power 105 PS / 103.5 bhp (77.2 kW) @ 7,750 rpm105 PS / 103.5 bhp (77.2 kW) @ 7,750 rpm
Max Torque112 Nm @ 4,250 rpm112 Nm @ 4,250 rpm
Front suspension43mm USD Marzocchi forks, 120mm travel43mm USD Marzocchi forks, 120mm travel
Rear suspensionTwin Marzocchi RSUs with external reservoirs and adjustable preload, 116 mm wheel travelTwin Öhlins RSUs with external reservoirs, adjustable for preload, compression and rebound damping. 123 mm wheel travel
Front brakesTwin Ø 320mm floating discs, Triumph branded four-piston radial calipers, OCABSTwin Ø 320mm floating discs, Brembo Stylema M4.30 radial calipers, OCABS
Rear brakesSingle Ø 220mm disc, Nissin 2-piston floating caliper, OCABSSingle Ø 220mm disc, Nissin 2-piston floating caliper, OCABS
Seat height805mm810 mm
Wet weight216 kg216 kg
Fuel tank 14.5l14.5l
TyresMetzeler Sportec M9RRMetzeler Racetec RR K3
Riding ModesRain, RoadRain, Road and Sport
Standard equipment Optimised Cornering ABS and Traction Control​; LED headlights with DRL; Cockpit mounted USB-C Socket​Optimised Cornering ABS and Traction Control​; LED headlights with DRL; Triumph Shift Assist up and down quickshifter​; Sports suede seat with stitch detail​
Optional equipmentOhlins adjustable RSU​; Low handlebar kit​; Cruise control kit – DRL​; TPMS Tyre pressure monitoring system​; MyTriumph connectivity module​; Scrolling LED Indicators​; Triumph Protect ​; Triumph Track; heated gripsLow handlebar kit​; Heated grips​; Cruise control kit – DRL​; TPMS Tyre pressure monitoring system​; MyTriumph connectivity module​; Scrolling LED Indicators​; Triumph Protect+; Triumph Track+
Engine
Both the 1200 and RS are sporting the HT (high torque) Bonneville liquid cooled 1200cc parallel twin engine pushing out 112 Nm @ 4,250 rpm or torque and 77.2 kW @ 7,750 rpm of power with 103.5 bhp.
The new Speed Twins have a 5 PS increase over the previous model in top end power with the engine being Euro 5 compliant.
If, like me, you love the unmistakable sound of a twin, then you will love the distinctive deep throaty sound of the Speed Twins. You can just feel the grin spreading across your face when you drop a gear and open up the throttle 😬
Chassis
The tubular cradle steel frame houses the engine with the 1200 having 43mm USD Marzocchi forks with 120mm travel on the front and twin Marzocchi RSUs with external reservoirs and adjustable preload with 116 mm wheel travel on the rear.
The front brakes are Twin 320mm floating discs, with Triumph branded four-piston radial calipers and the rear having a single 220mm disc, and Nissin 2-piston floating caliper.
The RS is sporting top-spec Marzocchi 43 mm USD forks which are fully adjustable; and the rear having twin Öhlins with piggy-back suspension units which are fully adjustable.
The Brembo master cylinder is paired to premium Stylema calipers, as well as a span and ratio-adjusted MCS lever.
The brushed stainless steel two into two exhaust system with twin silencers really do complete the look of this bike giving it a modern look with a contemporary twist.
Ride by Wire Throttle & Modes
Both the 1200’s have ride by wire throttle – instead of having a throttle cable connected to butterflies in the inlet, it will all be controlled by electronics and the twist grip sends an electronic signal to the ECU.
The 1200 has two riding modes: rain and road. The RS has three riding modes: rain, road and sport. The modes can easily be changed, even when riding, by using the mode button on the left bar and then using the up and down arrows.
Scrolling through the screen is easy to do (even for me!) and allows you to decide what you see on the screen.
I thought the 1200 in road mode was absolutely brilliant, handled nicely, felt good in the corners and was a really nice bike to ride.
I was not as keen as the RS either in road or sport mode. The bike was more ‘focused’, giving a harder rider and, I felt, was not as much fun to ride as the 1200. I definitely didn’t have the same grin factor as with the 1200.
Instrument Display
The twin analogue clocks on the Speed Twins of old have been replaced by a single colour TFT screen, which looks to come from the Triumph Trident. The clock is offset to the left and has a USB-C socket sticking out on one side.
To be honest, I am not a fan of the new clock, it really is not in keeping with the style of the bike. It would appear that I am not the only one of this opinion, judging by the comments received when parked up.
The clock however, does do very well what it is intended to do. The screen is clear to read, especially glancing down when riding. Everything you need to see is there – speed, revs, trip, what gear you are in, time, fuel gauge etc.
There are arrow keys on the left bar for you to scroll through the menu and have on display what it is you want to see. It is easy enough to use these keys whilst riding too should you wish to change what you see.
Tyres
The tyres on the ST 1200 are Metzeler Sportec M9 RR which Metzeler describe as “The Supersport tyre for your daily leans, enhancing the pleasure of riding without worrying about the unexpected, be that changing asphalt or weather conditions’.
Metzeler say these tyres are the first Supersport tyre to feature high-silica and full-silica compounds for both front and rear offering high grip from the first corner with the tyres performing optimally at low temperatures with their warm up speed.
The Supersport tread design is for optimised water drainage with the grooves delivering outstanding stability by draining more water as speed increases.
I thought these tyres were okay, not the best I have experienced but they performed okay. I had the bike on loan in early March so the temperatures were generally between 5 to 10 degrees, a little bit greasy from the salt on the roads and at times damp/wet.
I honestly don’t think I would keep these on the bike for long, I prefer a more all round trye that gives me confidence when riding. I didn’t get that feeling from these tyres.
The tyres on the ST 1200 RS are Metzeler Racetec RR K3 which Metzeler describes as a road and racetrack tyre developed to win road races delivering maximum performance.
Metzeler says that road racing courses feature multiple and variable conditions and the Racetec RR have been designed to cope with all of them with their versatility of use on a wide range of asphalts and temperatures.
I did not like these tyres, especially in the wet. I had the bike mid to late March with temperatures between 5 to 15 degrees, with salty roads and, at times, wet. I felt there was a distinct lack of feel of the bike with these tyres on wet roads. I felt my riding style changed and I tiptoed along.
I would change these tyres straightaway to a more all round tyre which works well in all conditions be it hot, cold, wet or dry.
Personally, I do not think this type of tyre should be standard OEM on a road bike. The vast majority of people will never do a track day and do not ride with their knee down around corners.
What are The Triumph Speed Twins 1200 & 1200 RS Like To Ride, I hear you say?
Well, interestingly, I found both the bikes very different to ride.
The 1200 is a really nice bike to ride, very smooth in its power delivery, handles nicely in the corners and this bike put the biggest grin on my face.
The suspension on this bike has been improved over my 2020 model and I could feel the difference, it gives a much nicer ride.
The riding position is also different to my bike, more focused, and although it is noticeable, I very quickly got used to it and it soon felt natural.
The RS was not such a nice bike to ride. Don’t get me wrong, it went like stink (as does the 1200) but I felt the bike was too ‘focused’.
The ride was harder and although it handled well, I didn’t think it was as smooth to ride. I thought the quickshifter was a bit clunky, certainly not the smoothest one I have used.
I prefer the colours and design on the RS to the 1200 but, that of course is just my personal preference.
I much preferred the Sportec tyres on the 1200 to the Racetec on the RS. I could live with the Sportec’s for a while but ultimately I would swap them for a more all round, everyday tyre, like the Michelin Road 6’s.
The Racetec tyres I would have to change straight away. I was riding on wet roads with these tyres and they were not nice at all. I did not like the feel of the bike in these conditions and had to change my riding style to accommodate the lack of feel I was receiving.
Both bikes weigh 216 kg, but the seat heights are slightly different – 805mm on the 1200 and 810 mm on the RS. To be honest, I didn’t notice the difference. I found moving both bikes around was okay, and at 5’6” my feet were nicely on the ground.
The brakes are responsive on both bikes (which is always a good thing 😜) I did not think the Brembo brakes worked better over the Triumph ones. There is a lot of engine braking with the Speed Twin so just lifting off the throttle scrubs off some speed.
The 1200 is very torquey and riding around town at low speeds is not a problem. Find an open road though, and now you’re talking, you can tell these bikes like an open road with fast flowing bends and tighter twisties, the bikes just soak it up.
The sound of the twins on start-up always sends a shiver down my spine and then the rumble from the engines at low speeds always have me grinning under my helmet. I find myself having a little chuckle when I open the bike up as I head out of town onto an open road, the noise is addictive.
Both the Speed Twins are easy bikes to ride. I use my Speed Twin for both everyday riding and touring, it is comfortable enough to be able to do this, although I do have a woolly seat cover when touring as I find my seat uncomfortable after a while. I would say both the new 1200’s would make great touring bikes too.
With both the 1200’s, I did experience wind buffeting especially when on a dual carriageway/motorway, and would put a screen on the front to cut this down and, hopefully, stop this happening. I have a screen on my Speed Twin and found this to have worked.
The clock is probably my biggest gripe with the new Speed Twins, the single digital clock is definitely not in keeping with the style of the bike. I know when you’re riding a bike you are not actually focused on the look of the bike or the screen but, when parked up and admiring your steed, appearances are important.
I would swap my 2020 Speed Twin 1200 for the new Speed Twin 1200.
I would not swap my 2020 Speed Twin 1200 for the new Speed Twin 1200 RS.
Not the verdict I would have expected. Before I rode both bikes, I just assumed that it would be the RS that would be my bike of choice but how absolutely wrong that assumption was.
Even though you are getting sport mode, Brembo brakes, Ohlins and a quickshifter on the RS, I would not pay the extra £2,000 for these.
I would be very interested to hear what you think of the 1200 and the 1200 RS – which one would you go for/have you gone for?
Thank you to Triumph UK for the loan of both the Speed Twin 1200 and 1200 RS.
BK
The post 2025 Triumph Speed Twin 1200 & Speed Twin 1200 RS Review appeared first on BikerKaz.
