motolover Posted April 9 Posted April 9 I have a 21 plate sinnis terrain at the moment and all the stuff on the bike works completely fine. But when I turn the bike on to run, it runs fine for about 30 seconds to a minute and then will go lumpy and cut out. If you try to restart it then it wont run until you turn the kill switch off and on again then it starts with no problems then will later cut out. Please help!!! Quote
bud Posted April 10 Posted April 10 Perhaps it has corrosion inside the switch? It's got to be worth a try cleaning it. Quote
Capt Sisko Posted April 10 Posted April 10 Is it a fuel pump issue? If gravity is refilling the lines whilst the bike is switched off there'll be enough fuel to start & run it for a short amount of time, but if the pump isn't working or at least not efficiently it'll not replace it and hence the engine stops. Can you hear a whur as the ignition comes on. That said most pumps aren't noisy and you very quickly stop hearing the assorted whurs & ticking noises modern systems make at start up or shut down. Quote
