Gregor Posted April 26 Posted April 26 Hi. I've bought my first cheap runner which is Lexmoto Arizona 125. Older bike . All works fine ,but looks like it has some throttle blockage course when I open it more than half it takes power down , up to this level everything is fine . My question is how to unblock it to get the full "power"? Thank you Quote
bud Posted April 26 Posted April 26 Could be a blocked main jet. Dirty air filter, or exhaust. If you take the carb off to clean it. Check that the slide opens all the way when you twist the throttle. Quote
