asharin Posted December 3, 2008 Posted December 3, 2008 I was hoping it might say in my haynes manual but alas no What sort of measurements are the mirrors on the SR 125? I don't like the ones that it has currently and would like to replace them Are there specific ones I need or can i use generic ones? Quote
Guest Posted December 23, 2008 Posted December 23, 2008 you can get any mirrors from an aftermarket range, just ensure they are Yamaha fitment, as the bolts are 10mm, instead of the 12mm, found on most other machines, then it's up to you for size, arm length and style.. after all you don't want to look to your rear and find that all you can see is your elbows or topbox..Frankie Quote
