Guest Posted February 8, 2009 Posted February 8, 2009 HiI bought my bike with only one key unfortunately, (the owner had lost the others!!).The bike is an 04 FZ6 with a built in immobilizer.Apparently you need the master key (red fob) with which to make copies and I dont have that one typically!!therefore will I have to change the ignition unit??Is it diy-able and roughly how much am I looking at?many thanks Quote
Guest Posted February 8, 2009 Posted February 8, 2009 HiI bought my bike with only one key unfortunately, (the owner had lost the others!!).The bike is an 04 FZ6 with a built in immobilizer.Apparently you need the master key (red fob) with which to make copies and I dont have that one typically!!therefore will I have to change the ignition unit??Is it diy-able and roughly how much am I looking at?many thanks dig out your owners pack, or go and see the dealer they should be able to help you, i don't thuink its DIYable, and a new ingnition etc on a new ish bike would probably work out more expensive than a new master key... also you'd have to change the other locks to match.. Quote
Guest Posted February 15, 2009 Posted February 15, 2009 You should be able to get the key code from any yamaha dealer (you will need proof of ownership though), and they can make a key from that. Quote
