Guest Posted April 5, 2009 Posted April 5, 2009 This part is confusing me! I want one, but i dont know what to get. Like, what will fit etc.I dont want the completel exhaust system as itll be expensive and the Sachs is a 2 stroke, so i need an expansion chamber.But im still really confused on this matter. Any advice / knowledge would help!Thankshttp://img401.imageshack.us/img401/2931/sachsxtc1252001.jpgAs you can see, the normal exhaust just doesn't do it justice.Oh, and the Engine is a Yamaha TZR 125 Engine, and the bolt distance from each other on the pipe to the can is around 45mm in distance. Quote
Guest Posted April 5, 2009 Posted April 5, 2009 This part is confusing me! I want one, but i dont know what to get. Like, what will fit etc.I dont want the completel exhaust system as itll be expensive and the Sachs is a 2 stroke, so i need an expansion chamber.But im still really confused on this matter. Any advice / knowledge would help!Thankshttp://img401.imageshack.us/img401/2931/sachsxtc1252001.jpgAs you can see, the normal exhaust just doesn't do it justice.Oh, and the Engine is a Yamaha TZR 125 Engine, and the bolt distance from each other on the pipe to the can is around 45mm in distance.you dont need an expansion box, thats near the front you need an end can, search google.http://www.wellerracingcorporation.com/ ... Parts.html 170 for one thats high level under the seat. Quote
Guest Posted April 5, 2009 Posted April 5, 2009 Yeah i know its An end can i need, i must have missed that out.Ive looked on google, you have to be careful because all the mods for sach's are for the newer 4 stroke one. The under seat exhaust is the default for the 4 stroke ones, i cant do it on mine because the ( i think its called downpipes?) Pipes leaving from engine to Can have a bloody big Expansion chamber in it. Quote
Guest Posted April 5, 2009 Posted April 5, 2009 Yeah i know its An end can i need, i must have missed that out.Ive looked on google, you have to be careful because all the mods for sach's are for the newer 4 stroke one. The under seat exhaust is the default for the 4 stroke ones, i cant do it on mine because the ( i think its called downpipes?) Pipes leaving from engine to Can have a bloody big Expansion chamber in it.as its a tzr derivative, see about an end can for one of them, they were all strokers otherwise, google stinkwheels, they'll be able to advise you of all things 2 stroke Quote
