Just bought a chain oiler from http://www.chainoiler.co.uk/ and am currently on Step 2 of the instructions, on the "dry run" they recommend before i actually start work.
And needless to say, i'm stuck already.
"2. Take one small cable tie and curl into a circle (teeth inward). :D
Insert into teacup (A) and add boiling water then cool. This will curve tie to shape. :("
The question is, what is "teacup", as the diagram really doesn't help much.
Here's some pictures and i hope they help one of you, because they certainly don't help me!
The bits in the box.
Diagram
exactly what it says, you'll find one in the kitchen. otherwise known as a MUG!!!
EDIT : PMSL
the idea is to use boiling water to get the plastic to mould into a circle..
I knew that, was just testing you all :D
Ugh, oops! ROFL at my mistake!
Thanks for pointing out the obvious guys, i genuinely thought they'd called one of the parts a "teacup", so i was looking for it :oops:
i think this was a big clue....
teacup or MUG
