Honda 1983 CB125
Hi
I went to look at a Honda CB125 last night as i thought it would be a good first bike for me, however it would not start! I said that if you could get it to start i would have it. I don't know alot about bikes but the battery was flat and they were trying to start it from 12v car battery i did ask if that was ok to do that and they said it would be fine!
They couldn't get it to start but i still really like the bike and they didn't want much for it? Should i keep away from the bike is it bad news!
Ta
Sounds like a strange one to me. Personally I'd walk away, there're plenty of other bikes out there (that start!). Starting off a car battery is OK, but only as long as the car isn't running, because it can surge the electrics on the bike.
If they're asking for £200 for it then it's a different story, but if the asking price is the same as others that definately do work then just forget about it.
Thanks for your reply and advice
I said i would give them £300 if it would start, i could maybe get it for less as it won't start! But as i don't know a great deal about bikes or what is wrong with it i don't know what to do????
i also think that the CB125 is 6v so would starting it from a 12v battery cause a problem???
Posted (edited)
I've had my car jumped by a 24v battery, when i was stuck at the port.. no-one would help except the port officials, everyopne else thought it was hilarious i'd broken down (Brand New Beemer at the time...)
but don't think they did the CB125 as a 6V, even in 1983.. my gp100 and katana (1982) were both 12V, think the 6V was for 50cc and phased out quite soon..
yep changed to 12v in 1982
http://www.whitedogbikes.com/hondabatteries.htm
Edited by Anonymous
ok then if it is 12v then it shouldn't be a problem, i just thought it was 6v!
We did try to bump start it and we got a bit of smoke from the exhausts but it just wouldn't pick up!
Can you still jump a bike if the battery is completey dead??? specially a 26 year old bike!!!
yes, because the jump bypasses the battery
did it have fuel... and when was it last running...
Was last running about 3 months ago
Did have fuel and checked the fuel cut off switch, to me it sounded as if it was sparking, starting and then cutting off!!!
fuel problem, could be gummed up jets.. have a look at other posts this has been covered many times
Hmmmmmmm
If you don't know much about bikes then this could be a great project to get your hands dirty on. You could do allsorts like stripping the carbs (or carb if it only has one), taking bits off, putting bits on, learning about bikes! £300 isn't bad if you can get it going. Knock them down a bit, even if they say they can't go much lower, keep pushing for less ;)
Of course if you're not up for getting your hands dirty and taking bits apart then I wouldn't bother. To get it going again, if you don't know what's up with it you could pay a mechanic lots to sort it. Much better to do it yourself as it'd be free :D
I am liking the idea of that, learning about bikes getting my hands dirty! but with it not starting i don't even know what to check what to look for??
and it's a twin! (that's about all i know) lol
