mattrick Posted October 11, 2009 Posted October 11, 2009 husqvarna enduro 50cc great fun on and of road.just fitted front brake light switch and ran the two wires straight to the back light.now the front brake light will only work with the lights on.why is the lights cutting the power to the brake light?do i have to run another wire from somewhere else to get power with the lights of. bike has magnito and no battery dont know if that helps. need help,thanks. Quote
Guest Posted October 11, 2009 Posted October 11, 2009 if it has no wiring for a front brake light, then take a feed from the rear, you'll need some cable to run under the tank etc.,.... Quote
mattrick Posted October 12, 2009 Author Posted October 12, 2009 can i just cut into the rear brake switch wiring and join the two from the front one straight into the rear one. Quote
Guest Posted October 12, 2009 Posted October 12, 2009 yes, get some 2 core wire, and run from the switch on the bars, to the switch on the pedal, when either switch is depressed the light will activate.. i would test before running the wires through the frame/under the tank etc..piggy back connectors mean that you don't need to cut any wiring... find them in halfords... Quote
mattrick Posted October 12, 2009 Author Posted October 12, 2009 thanks for help.hopefully no more head scratching. Quote
