Probably a stupid question but Im gonna ask anyhoo
I have been cleaning my bike and noticed the can is loose
So I checked it out and the bracket holding it in place needs tightening, no biggy there.
I also noticed that the joint to the `downpipes is loose so I decided to check further
can removed and there is not sign of any sealing paste.
Is the paste required or should it be just a push fit with no need for sealing?
Cheers
:cheers:
130 mile trip Roy
I just wondered if I should smear some paste in the joint to seal it. It's the extension pipe where it meets the downpipes
Probably loose due to me dropping it :oops:
Exhaust paste is only required to achieve a gas tight seal. If it 'blows' when its running, then it needs some.
Lol Dan
Its fooking noisy anyway so im not altogether sure if it ios blowing
There does seem to be some soot like dust in the sleeve
So probably best if I use some paste, but from experience I know this will make removal a lot harder.
doesn't need loads..
To check, run bike and either hold hand around seal to feel if it is blowing, or get a smoker to blow smoke around it...
DUH!!!!
I shoulda know that Dan :oops:
Thanks
Blowing a little................not much though
So a smear of paste it is
Just wasnt sure whether to use any or not
Never had to use it on the GSX, but that has a standard exhaust system and humungous gaskets :wink:
If it was the car it would have gotten loads :lol: :lol: :lol:
Thanks :thumb:
:cheers:
Both my cans slip on and off and there is no seal, just a slot for the can to slip into. There is also a spring that connects the can to the main pipe to get a tight fit and it doesn't blow so no paste required.
However, as peeps have said, if she blows then paste is required ;)
