guybandit Posted June 22, 2010 Posted June 22, 2010 Hiwell ive fitted a reconditioned swingarm to my bandit and it look awesome. Bleeding the rear brakes and sheared the bleed nipple flush with the calliper. looked on E-Blag and for a new one its over a ton and about 50 for a used one but most dont state if the pins or nipples are siezed.Anyone got any ideas as to getting the stud out, ive heard of extractors, where you drill a whole down the center and then thread it out i think. Anyone got any experiance of thisReally wounded as its traken me two weeks to spray the swingarm and get the old one off and the weather is mint.Any help would be appriciatedThanks, Guy Quote
Guest Posted June 22, 2010 Posted June 22, 2010 several options ... take the caliper to a local engineering firm, and they'll get it out for you.go buy a stud extractor... basically it has a left hand thread, so as you turn it into the hole in the bleed nipple, it transfers the left handed motion to the snapped nipple and thus it unscrews.. in theory...drill it out .... if you are not minded that way, it'd be safer if you took the caliper to a firm with the kit. literally a 10 minute job ... (well it should be lol ) Quote
guybandit Posted June 22, 2010 Author Posted June 22, 2010 Thanks for that, ill source a set and give it a crack. try not to f**k it up any more eh.Cheers, Guy Quote
Guest Posted June 22, 2010 Posted June 22, 2010 as its a bleed nipple it will have a hole down the centre so just screw in an extractor and undo. if you send me a pm with your addy i'll send you a bleed nipple. Quote
Guest Posted June 22, 2010 Posted June 22, 2010 might be useful...http://www.themotorbikeforum.co.uk/view ... 77&start=0 Quote
guybandit Posted June 22, 2010 Author Posted June 22, 2010 yep did all that, scrubed up a treat, should of stripped the nipples out then though i guess. spoke to a metelsmith at work, he has a set of extractors so give that a go. Just wanna get back out on it now. Quote
Guest Posted June 22, 2010 Posted June 22, 2010 (edited) have dug out a speedbleeder nipple, it has a sprung bearing inside. the bearing is pushed with the fluid/air pressure then reseats itself, saves tightening and lossening when bleeding, i never got on with them, but cant find a normal one in my kit..#EDIT i use a reverse bleed method, so the bearing gets in the way, Edited June 22, 2010 by Anonymous Quote
guybandit Posted June 22, 2010 Author Posted June 22, 2010 Sounds good, ill give it a go, i know if i go to a shop ill have to buy a bag of 5 or 10 probably. Quote
