Hi,
just been working on the bike trying to get to a leeky oil drain pipe that i thought was causing the leak (posted about this agessssss ago... only just got round to looking).
to get to this i had to take the head off, i was just about to do this (i.e. i had the valve cover off).
was just about to unscrew the exhausts when i spotted a potential higher-up oil leak...
right down the center of the head at the front there was clear signs of a leak, i quickly jumped up and inspected the valve cover.
its been cracked and welded (although my dad reckoned it was soulder) and because of this the gasket just doesn't mate propperly..
It looks like a bit of a bodge really. I don't suppose it would have caused a major issue really - just a constant leak..
My problem now is sourcing a replacement valve cover. Ebay is looking promising but just wondered if anyone could recommend any breakers or anything or may even be breaking one. - you never know!..
cheers
Chris
Google Breakers there is a website that charges about £2 you tell them what you want and they send it out to loads of Breakers.
Used them before but like a Numpty Didnt save the address.
the GSX600F head is one fitted to many of Suzuki's past range, OldSkoolSuzuki will advise what models will fit such as the early Gixers, and the 1st Gen Bandit's
oldskoolsuzuki.info - infoboard - oil cooled
managed to get one from a seller on Ebay who breaks bikes. 20 quid inc. postage so can't complain.
should be here in the next few days so should be on the road soon as!
OSS say inspect the spark plug seals as it they havent been fitted the head leaks above the exhausts .... theres drains for the plugs for water ingress
