Guest Posted July 15, 2010 Posted July 15, 2010 Hi,thanks for any help offered....My partners bike.1988 honda cbr600 finally found problem why it wouldnt start needed a new cdi unit..Now after checking several things like spark..leads fuel etc the bike is only firing on 2 cylinders i think as left side exhausts are cold to touch but ride side 2 get warm,can the valves be getting stuck as it was sat for a while,??? was told by mate to empty oil from sump fill with diesel run bike for 30 secs at about 1200 rpm then drain fill with cheap oil drain again the fill with decent oil ..thus releasing any build up of coke due to idleness,he is a bit dubious and it seems longwinded,i suggested a blast of easy start on the plugs, not to sure, any help would be appreciated ty dawn Quote
