DeeJ Posted August 11, 2010 Posted August 11, 2010 Recentely got my bike running again which turned out to be a stuck starter motor.I have charged the battery up and it reads between 11.5 - 11.8 with the ignition on, the electric start works fine and starts the bike up easily.At idle the reading is the same as ignition on 11.5 to 11.8.Then revs held at 5k, slowly goes up to 13.5 to 14.0Then when put back down to idle, it goes back down to 11.5 to 11.8Can anyone shed any light on this. Quote
j4ff Posted August 11, 2010 Posted August 11, 2010 Mine will read 13-14 at idle and 12.3 standing(no ignition).If your only concerned is when your ignition is on(not started) but it holds a charge and charges,is it not just the fuel pump priming or ecu or lights taking up a bit of power? Quote
DeeJ Posted August 11, 2010 Author Posted August 11, 2010 Mine will read 13-14 at idle and 12.3 standing(no ignition).If your only concerned is when your ignition is on(not started) but it holds a charge and charges,is it not just the fuel pump priming or ecu or lights taking up a bit of power? I'm just concered at idle reading below 12v, this normally means the battery is not getting charged, and with me owning a 2 stroke it is idling alot to get it to temperature.The battery was only bought 4 months ago, but I have lost the receipt, so going be arsey and pushy to try and get a new battery and hope that reads better Quote
eastanglianbiker Posted August 11, 2010 Posted August 11, 2010 with the ign on and the bike not running it might well show just below 12 volts as the neutral light and oil light will be drawing power but the reading you are getting at revs is about right to get an odd reading like like you are is not likely the battery having a problem as each cell of the battery is 2 volts Quote
Fozzie Posted August 12, 2010 Posted August 12, 2010 It sounds normal, unless you have difficulty starting it and you can prove it isn't the 2-stroke being... Well a 2-stroke then I wouldn't worry. Quote
