Now i have just replaced the copper gaskets on my Gt 550 and its still blowing like a hurricane :crybaby: what do you guys usually do as the clamps etc are all tight.. do you use assembley paste or guim gum etc?
also check that the studs are located correctly/fully as loose or protruding studs wont aid fitment... best to fit them with loctite before bringing up the pipes... and use coppergrease on the nuts.. (aids removal later )
its a non standard Motad 4 into 1 system so its slightly different... howev4er i did use all the correct bits.. gaskets sleeves and finally clamps...
i cant tell to be honest as the noise off the one overrides the others and i cant get my hand around the pipes for the heat... i dont think they ar eall blowing to be honest as it only seems like the one but i cant be sure
try loosening them (not all, the way), and then tighten in succession (a little at a time), i.e number the studs l-r 1-8
do 1, 8, 3, 6, 2, 7, 4, 5...
this will bring the headers in square and tight on all cylinders, could be they are slightly out, and thats why your blowing..
