Posted (edited)
bit not like any cut out i've come across!!
its a 1996 GSF1200 bandit
i will come to a stop and it will, over the space of about 2 seconds, drop in revs then cut out....
it doesnt always do it though!
also i noticed, when in gear with the clutch fully in, if i rev it, it will still pull foreward slightyl!
makes me wonder if the clutch thing is making it stall at a standstill?
its a hydraukic clutch so i dont see any way of adjusting it :?
cheers all
Edited by Foz
change the fluid, to rule that out, but yes, sounds like its the clutch
well i changed the fluid this afternoon! was a nice and easy job :D
anyway, the old fluid...was black!! i don't think its ever been changed!! :shock:
i put new fluid in and took it for a test ride, everything is as it should be! no cutting out, when holding the clutch in and revving, it no longer pulls at all!! :mrgreen:
wit will be tested further
cheers for the help you two! i will probably need a lot more with my new GTR project
