stevie16v Posted December 27, 2010 Posted December 27, 2010 Bought a fixxer upper. Divi 600 on a 94 plate, 30k on the clock, Had been sitting for about 4-5 months. Was assured prior to that it was a perfect runner. I've got it in the garage, cant for the love of me get it started.I've made sure the battery is fully charged. Theres fuel in it. Starter motor turns but the engine doesnt catch.I've connected the fuel tank to the carbs and prime setting so as to fill the carbs so to bypass the fuel pump (which appears to working ok anyway. Still not firing up tho. Plugs are new aswell.Can someone give me a step for a hint what to try etc?Cheers Quote
eastanglianbiker Posted December 27, 2010 Posted December 27, 2010 did you check for a spark at the plugs when fitting them,have you checked engine kill switch is in the run position,have you tried to start it with bike upright you sitting on it and side stand up in case the switch is faulty,is the neutral light on and also try holding clutch lever in,could be any of these,also did you put new fuel in tank or trying to run it on the old fuel as that might have gone stale Quote
stevie16v Posted December 27, 2010 Author Posted December 27, 2010 Havent checked for a spark. Just took for granted it has one. Whats the best way to do this?Kill switch is in the correct position, if i flick it to off the starter doesnt engage. I've tried it with the side stand up and down, not tried doing it sitting on it, but have been doing it whilst on the centre stand.Neutral light is on. Also tried holding the clutch in aswell but no joy. Still the existing fuel in it, will try fresh stuff. I thought it would have kicked over slightly tho even with slightly older fuel in it, It doesnt have that horrible stale fuel smell either Quote
eastanglianbiker Posted December 27, 2010 Posted December 27, 2010 to check for spark remove one of the plugus from the engine then put i back into its cap rest it on the engine flcik engine over on the starter and see if it sparks use same plug in each cap to check that each one is sparking.also if it has been sat around for some time then the fuel might of blocked up the jets in the carbs.you might need to remove each float bowl in turn and check the jets are clear Quote
stevie16v Posted December 27, 2010 Author Posted December 27, 2010 I've removed the carbs and sprayed carb cleaner in through the main inlet which comes from the pump, It's spraying out of each inlet to the carb bowl. Had a look at each jet too and they look ok, can't see anything obvious blocking them. Got the battery back on charge just now as it has died for about the third time after trying repeatedly to start the engine Quote
eastanglianbiker Posted December 27, 2010 Posted December 27, 2010 then check spark and if need be remove top of air filter remove filter itself and spray small amout of carb cleaner into carbs as u turn bike over if its going to start then it wil start on carb cleaner Quote
stevie16v Posted December 27, 2010 Author Posted December 27, 2010 sounds like a plan. I've taken the four plugs out tonight, oddly i could only smell petrol from one of them, it had been a few hours since i tried turning the engine over though. I'll get fresh fuel and carb cleaner tomorrow see if that makes a difference. Dont know how much punishment the battery can take tho. Might need to hook it up to the car Quote
eastanglianbiker Posted December 27, 2010 Posted December 27, 2010 be carefull hooking it up to the car as the amp rates are very different and in some cases can cook the bike battery then it is usless Quote
stevie16v Posted December 27, 2010 Author Posted December 27, 2010 will do. might try get a hold of a starter pack then, just to give myself a bit extra power incase maybe the battery isnt quite cutting it anymore Quote
rennie Posted December 28, 2010 Posted December 28, 2010 same thing for starter packs! only safe if it's got a bike setting.at a push I connect to my car battery BUT!!!! don't run car enginewith it connected!I would go for the problem being stale fuel! Quote
stevie16v Posted December 28, 2010 Author Posted December 28, 2010 Thanks for the replies folks. Got up this morning, took out the plugs and checked for sparks, all good, Primed the fuel system and made sure the pump was working (diaphragm type), then popped it back together, Caught after 3 tries and it fired up on 1, 2, 3 etc. But it sounds a bit rough, similar to a v-twin. Wondering if its maybe not running on all cylinders yet. Idle is slightly eratic. Could prob do with a carb balance etc. and its got the clutch rattle so i'll get that sorted out too. Apart from that its just going to be wee odd jobs to get it back to strength Quote
eastanglianbiker Posted December 28, 2010 Posted December 28, 2010 glad you finally got it running have a quick look at the plug on the cylinder that isnt firing see if plug is wet or dry if dry check spark again then need to check jets in that carb Quote
stevie16v Posted December 28, 2010 Author Posted December 28, 2010 Thanks, I'll need to leave it a few days because i'm heading back up to mine (bike is at the in laws) and the mrs feels slightly neglected. Silly question, But would the down pipe from the cylinder that isnt firing, be colder? Quote
eastanglianbiker Posted December 28, 2010 Posted December 28, 2010 yes it would be but please be carefull when trying to find out dont stick ur hands onto hot pipes....lolcan check with fingers after running fora few seconds but after that splash bit of water onto each pipe Quote
