mealexme Posted January 21, 2011 Posted January 21, 2011 so, when indicating right, it doesnt work properly. if i hold the... indicator switch to the right, it works. When i cancle it, it flickers, but if i just flick it to the right and let go,nothing happens. The left one works fine. Quote
eastanglianbiker Posted January 21, 2011 Posted January 21, 2011 sounds like the switch needs cleaning up or the flasher relay is on ites way out try spraying some switch cleaner in around the contacts on the switchgear first Quote
mealexme Posted January 21, 2011 Author Posted January 21, 2011 sounds like the switch needs cleaning up or the flasher relay is on ites way out try spraying some switch cleaner in around the contacts on the switchgear firstnot got any of that, don't even know where to get it lol. i have WD-40 though. will that do? Quote
eastanglianbiker Posted January 21, 2011 Posted January 21, 2011 http://www.halfords.com/webapp/wcs/stor ... yId_165750 works differently to wd40 Quote
mealexme Posted January 21, 2011 Author Posted January 21, 2011 http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_195717_langId_-1_categoryId_165750 works differently to wd40well will WD-40 work? because i am planning on selling the bike and don't fancie the 20 min ride there to buy something i will prob never use again lol. i also have a muc off degreaser to get rid of grime, Gt85 which gets rid of water and loosens rusted parts etc. any of that any good or do i really need that other stuff? Quote
eastanglianbiker Posted January 21, 2011 Posted January 21, 2011 give the wd40 a try it might just be the switch is sticky in which case it would help saves buying anything so got nothing to lose by it Quote
mealexme Posted January 21, 2011 Author Posted January 21, 2011 give the wd40 a try it might just be the switch is sticky in which case it would help saves buying anything so got nothing to lose by itanyway it could make things worse? Quote
mealexme Posted January 21, 2011 Author Posted January 21, 2011 no alex, won't make it worse.Thanks dan,just making sure. don't want to completely ruin it. Looking for a quick fix usualy ends up making in worse in my experience. Quote
