Had my gsxr 750 on stands today and started it up knocked it into first so the rear wheel runs...
there is some god awful 'Clunking' noise and doesnt appear to be running smoothly, like small jolts as it goes round.
the front sprocket is tight, the rear wheel is lined up properly and the chain is lubed... may be a slight tight spot though?
any ideas? I will try record it and post video tomoz!
thanks
Check your chain for tight spots. Pull the very back of the chain straight back off the rear sprocket, any more than 3mm , chain and or sprockets are knackered!!! Look at teeth on both sprockets , are they shiny or hooked? Pix will help. :mrgreen: :mrgreen: :mrgreen:
Photos.... didnt have time to get a video though...
As shown in one pick i pulled the back away from the sprocket and it bearly moved.
http://i41.photobucket.com/albums/e293/BoB3rt/IMG_0202.jpg
http://i41.photobucket.com/albums/e293/BoB3rt/IMG_0201.jpg
http://i41.photobucket.com/albums/e293/BoB3rt/IMG_0200.jpg
http://i41.photobucket.com/albums/e293/BoB3rt/IMG_0199.jpg
also i have never seen a link like this... normal?
http://i41.photobucket.com/albums/e293/BoB3rt/IMG_0187.jpg
sounds like you could have a dry link on the chain somewhere.or could also be to much slack in the chain make sure its adjusted correctly and lube it see what happens then
