swing arm bearings
do any of you know if the swingarm bearings from a 2001 Yamaha XJR1300 will fit into the swing arm on a 2006 XJR1300
i have looked up the part number as being 93315 - 42523 the parts manual i have was published in 2001 so i assume i'm ok as my bike is 2001 ,I have taken the swingarm off my mates 2006 bike to send it off to Areocoat to be powdercoated so i have had to remove his bearings and need to know what to order
cheers guys
If the 2006 swinging arm is going back on that bike why don't you order the 2006 bearings? Any main dealer will be able to look up the part number for you.
Also I hope you have blanked off the holes where the new bearings are going to be pushed in. The powder coating can be a right pain the bum to get out if you havent. :(
Should have a number embossed on the dust shield... That will be the number of the bearing.. Yam parts stocker is probably the best way unless you have a local bearing stockist....
