hi all
hubby has a 02 r1
it keeps cutting out if he is under 2 and a half thousand revs,
any ideas?
he is r1 barry on this forum but doesnt ever post so im doing it for him
when was last service?
fresh fuel?
tickover need adjusting?
does he have a haynes?
tell the chicken to post :lol:
Guest akey
Could be throttle bodies need balancing
Could be Throttle position sensor
he has a haynes, it could be one of many things,
hoping to find someone in past with simular problem that may be able to pin point it a bit better rather than go through a hole list of things!
will show him forum thanks
also he doesnt do computers :lol:
Guest akey
Only reason I say Throttle sensor is its a weak point with a few bikes (tiger included).
Sounds like a loose connection on a sensor or ECU to me! Try unplugging, WD40ing and replugging several times to clean contacts. Also checkout Lambda sensor wiring??? ECU may be getting a false signal? :mrgreen: :mrgreen: :mrgreen:
