Help
Hi guys Nn gals, i just recently bought a yiben strider 125, the kick start does'nt work and they dont like early morning (well mine dont) and i start work anytime from 4.30am so i need some reliability, any advice would be greatly received cheers
its a 56 plate, and the battery only lasts for a couple of days at the most. also 2 presses of the electric start. but what about the kick start not working cheers
sounds like the battery isnt getting any charge or not holding a charge you need to check out if there is power going to the battery there should be 12volts on tickover and roughly 14 when revving just make sure rearwheel is off the ground when you rev it.is the kick start turning the engine over but bike wont start if so this is because batery is flat,if its not turning engine over then there is a problem inside the main casing
