Guest Posted June 10, 2011 Posted June 10, 2011 I have only had my 09 ybr 125 for 1 week now it has been fine all week but now there is no power in 4th gear. I have no knowledge of bikes does anyone have any ideas ?Thanks.Jon Quote
Guest akey Posted June 10, 2011 Posted June 10, 2011 when you say no power what revs / speed are you doing in 4th?? Quote
mealexme Posted June 10, 2011 Posted June 10, 2011 hey jon, if your planning on sticking around say hi in the "newbies" sectionI am not sure how to fix the problem, but there are many helpful users on here for if you decide to stick around Quote
Guest Posted June 10, 2011 Posted June 10, 2011 round about 30. but it does not pick up. I can normally get up 50 quite quickly.Thanks. Quote
Boothy Posted June 10, 2011 Posted June 10, 2011 You mean the YBR has power in 4th in the first place You could start with the spark plugs, although I am only guessing. *waits for EAB* Quote
Fozzie Posted June 10, 2011 Posted June 10, 2011 Does it work fine in all other gears? Can it get above 4th and then pull?Is the gear selecting properly? Is it slipping in differently to other gears?Or alternatively your fuel injection could be up the shitter in which case you will be needing a new ECU. Or we could get really simple if the answer to my first question is no... How loose is the chain? How dry is the chain. Tell me in CM how loose the chain is. Quote
Colin the Bear Posted June 10, 2011 Posted June 10, 2011 Poor engine performance may indicate a service is overdue. Is 4th top on this bike? You may be in 5th. Could also be brake dragging , clutch slipping, underinflated tyres, sudden rider weight gain Quote
mealexme Posted July 2, 2011 Posted July 2, 2011 to be honest my YBR does the same sometimes, i cant get the revs past about 8000 in 4th gear when it should hit red at about 11000, and can carry on going to 13000 (i think) which is a pain as you kind of have to thrash the nuts off it if you want to join the duel carriage way, and want to do over about 60mph... Quote
