martlewis Posted August 24, 2011 Author Posted August 24, 2011 Quick update, battery is on charge on optimate3. Didn't switch to desulfate, don't know if that's a good or bad sign.Once it's charged I'll get it back on and check voltages etc.Thanks Mark for the loan of the charger. Quote
martlewis Posted August 26, 2011 Author Posted August 26, 2011 OK so after 16 hours or so the charger started switching between charge and weak, it then went to desulfate for about 15 mins and now is charging again.Any suggestions if the battery is dead? Quote
Fozzie Posted August 26, 2011 Posted August 26, 2011 OK so after 16 hours or so the charger started switching between charge and weak, it then went to desulfate for about 15 mins and now is charging again.Any suggestions if the battery is dead? If it has to desulfate the battery then yes the battery was the problem...Sulfation destroys a battery's ability to hold charge. Desulfation is the curing factor here as it makes the battery more able to charge. Though a battery for your bike from Halfords is about £30 from memory. If you have a trade number all the better. Quote
martlewis Posted August 26, 2011 Author Posted August 26, 2011 OK so after 16 hours or so the charger started switching between charge and weak, it then went to desulfate for about 15 mins and now is charging again.Any suggestions if the battery is dead? If it has to desulfate the battery then yes the battery was the problem...Sulfation destroys a battery's ability to hold charge. Desulfation is the curing factor here as it makes the battery more able to charge. Though a battery for your bike from Halfords is about £30 from memory. If you have a trade number all the better. Wish I did have a trade number. Would that make it cheaper? Quote
Fozzie Posted August 26, 2011 Posted August 26, 2011 Using a mates trade number (you need them with you) I got 5 litres of oil, a battery and a set of 4 spark plugs for £38.Hence why for everyone else its wise to call them "Halfrauds" Quote
Horseynat30101 Posted August 26, 2011 Posted August 26, 2011 Using a mates trade number (you need them with you) I got 5 litres of oil, a battery and a set of 4 spark plugs for £38.Hence why for everyone else its wise to call them "Halfrauds" I also have use of one of these two headlight bulbs- £11.98. With card- £2.98 Quote
martlewis Posted August 26, 2011 Author Posted August 26, 2011 CMC clay cross £24.99, Halfrauds £49.99... But it's a Bosch battery, the man at halfrauds said, so that makes it ok Quote
martlewis Posted August 26, 2011 Author Posted August 26, 2011 Do I need to charge new battery once I put the acid in it? Quote
eastanglianbiker Posted August 26, 2011 Posted August 26, 2011 you can normally fit and ride off but if you still have akeys charger there it wouldnt hurt to put it on that for a couple of hours first Quote
Decor58 Posted August 26, 2011 Posted August 26, 2011 If it doesn't already have acid in it then it will probably need charging.However if you buy one with acid already in it shouldn't require charging. When I required one I phoned up the garage and they put the acid in and fully charged it for me ready for when I got there. Quote
martlewis Posted August 26, 2011 Author Posted August 26, 2011 Still got his charger so I'll give it a charge till it's time to go home then. Quote
sparkeh9 Posted August 26, 2011 Posted August 26, 2011 Just out of curiosity, what are you supposed to do with old batteries? Quote
Fozzie Posted August 26, 2011 Posted August 26, 2011 Take them to a tip and recycle them Some batteries come dry charged, which means you put the acid in, let it settle and then its good to go. Some need filling up and charging but thats about all i know Quote
martlewis Posted August 30, 2011 Author Posted August 30, 2011 It charged just over 2 hours in total. Bike is good as new again.Thanks to everyone for the help, and especially Akey for the charger. Have sent you a PPM mate. Quote
Guest akey Posted August 30, 2011 Posted August 30, 2011 No worries mate, just glad you got the bike sorted Quote
