Guest Posted September 28, 2011 Posted September 28, 2011 (edited) Hi all Please help like a knob I left my keys in the ignition all night (switched on), after charging the battery and fitting, the engine has developed a misfire....ticks over ok...could any other part have been damaged?The bike is a "03" FZS 600 Fazer.Have checked the plugs and there is a spark on each!Thanks for looking Edited September 28, 2011 by Anonymous Quote
TC Posted September 28, 2011 Posted September 28, 2011 I wouldnt of thought leaving the ignition on overnight would cause the engine to backfire. Quote
eastanglianbiker Posted September 28, 2011 Posted September 28, 2011 it could possibly cause a coil to over heat and break down under load as well have you given it a good run to make sure that it isnt just due to fuel pump overpriming if it has one? Quote
Guest Posted September 28, 2011 Posted September 28, 2011 No nether would i, have burt a coil out years ago...but wasnt electronic ignition..going to charge the battery again just to be sure.. Quote
Guest Posted September 28, 2011 Posted September 28, 2011 Ye will take it for agood run when traffic dies down.. Quote
