Guest Posted October 21, 2011 Posted October 21, 2011 Hi I have a zx400g import. when I switch the ignition on the front indicators come on and stay on. I dont like this and want them just to come on when i want to turn. can anyone advise me of which wires to disconnect if this is possible. thank you in advance. bazza. Quote
Bogof Posted October 21, 2011 Posted October 21, 2011 Hi I have a zx400g import. when I switch the ignition on the front indicators come on and stay on. I dont like this and want them just to come on when i want to turn. can anyone advise me of which wires to disconnect if this is possible. thank you in advance. bazza. I'd start off by checking your earthing points, particularly around the flasher unit Quote
mealexme Posted October 21, 2011 Posted October 21, 2011 notaclue...what happens if you turn them on? Do they flash? Quote
eastanglianbiker Posted October 21, 2011 Posted October 21, 2011 will be double element type bulbs so front indicators stay on as running lights you will need to find which of the wires going to them will turn off the duller element and if you can fnd any it would help to change the complete indicator units on the front at some point so you can then use normally single element bulbs Quote
