TC Posted December 30, 2011 Posted December 30, 2011 Oh and what dose TC stand for ? Only 2 people on here know. But you're welcome to have a guess Quote
Sigil Posted December 31, 2011 Author Posted December 31, 2011 im going to guess Thunder Cat as that what came to mind first. mabey a first bike or what made you fall in love with biking with... PM me if im right Altho at only 2 ppl knowing im guessing its not so obvious... Quote
Fozzie Posted January 1, 2012 Posted January 1, 2012 Mine got done the other day, because I had nackered bolts from a previous owner failing to remove it, it took some doing...Took an hour and a half or so to get the bike apart, cct out, and back together Quote
Sigil Posted January 2, 2012 Author Posted January 2, 2012 Mine got done the other day, because I had nackered bolts from a previous owner failing to remove it, it took some doing...Took an hour and a half or so to get the bike apart, cct out, and back together Dosent sound to bad to me .Im thinking of doing the oil, filters and sparks as well. Its only got 5k on the clock and had its services but 5K since 2002 so im thinking it wont hurt to refresh at least the oil and filters. Might as well do a service while the tank is off Quote
Colin the Bear Posted January 2, 2012 Posted January 2, 2012 Change oil and filter every year, even if mileage requirement not met. Oil goes off, so to speak and needs changing. Quote
Sigil Posted January 2, 2012 Author Posted January 2, 2012 Change oil and filter every year, even if mileage requirement not met. Oil goes off, so to speak and needs changing. Ah cheers, will be doing a oil change soon then Quote
