dispersion Posted May 14, 2012 Share Posted May 14, 2012 Ok, so done LOADS to my bike today.Well I took some parts off (gear lever, pillion foot rest and the thing that holds it together) and sanded them and polished them up and there looking pretty good.However as I am using my new found knowledge of basicmechanics and polishing I am noticing bits and bobs that i want to change/arnt there on my bike.I have ordered a 560 pc's set of the fazer 600 1999 stainless screws and bolts etc..and will be using these when they arrive but I have a question.Where do i find the exact size/item I want.The two i noted today was a spring for the pillion foot peg and the foot peg mount there is a washer type thing between the mount and where the bolt goes into the bike, one was missing (noticed when removing)Any ideas? I have haynes manual but seems to be quite tricky to find it (if its in there).Gareth Quote Link to comment Share on other sites More sharing options...
Guest Swagman Posted May 15, 2012 Share Posted May 15, 2012 Just a tip for you if you are putting stainless bolts into ally then put some copper grease on the thread so that the stainless doesn't react with the ally, Quote Link to comment Share on other sites More sharing options...
Boothy Posted May 15, 2012 Share Posted May 15, 2012 http://www.pro-bolt.com/index.php/pro-g ... 7KtcOtrNRE Quote Link to comment Share on other sites More sharing options...
