Raym Posted May 25, 2012 Posted May 25, 2012 Hi GuysDecided to have a go fitting my scott oiler and over tightend the brass spiggot and it has snapped in the exhaust port leaving half of it in so cant be removed with plyers Any advice on how to remove and what to do would be very very helpful Cheers Quote
Guest Hodgy Posted May 25, 2012 Posted May 25, 2012 If it's the hollow spigot the vacuum tubing goes on, a stud extractor should quickly and easily remove it Quote
Stu Posted May 25, 2012 Posted May 25, 2012 Exhaust port? If that's your vac line you won't get much vacuum from the exhaust! I'm hoping you mean inlet port? But to remove as above Quote
Raym Posted May 25, 2012 Author Posted May 25, 2012 Thats right mate inlet port .Thanks for the stud exractor , never heard of on until i googled it so its off to buy one Quote
