so i picked up my 2001 bandit on tuesday but the only thing bugging me is the indicators are flashing too fast!
the bike does have aftermarket rear indicators fitted but non led, is this just a simple matter of me needing a relay or something? if so shat type will i need and where a bouts is it situated on the bike ?
2001 bandit 600s
thanks ste!
yes its a relay you need or a resistor or you could just fit indicators with the correct bulb wattage :)
thanks mate i think il see if i can get a correct wattage bulb that will fit into these lenses before i go down the relay route!
