Guest Posted January 30, 2013 Posted January 30, 2013 I am hoping someone has a 2000 Kawasaki W-650 and can tell me where the hose from the cross tube between the carbs ties in. It is a large metal pipe with a hose barb in the middle that is inline with the round tube bosses on the outer sides for more carbs but plugged. Quote
eastanglianbiker Posted January 30, 2013 Posted January 30, 2013 are you sure the tube that comes off the piece between the carbs isnt the overflow and the hose should just run down to the rear of the engine to allow it to drain onto the floor if needed to Quote
megawatt Posted January 30, 2013 Posted January 30, 2013 It could also be a breather pipe. Can you post a piccy or microfiche drawing or a link? Quote
