Hot_Stu Posted May 1, 2007 Posted May 1, 2007 Friends, Does anyone know where I can get ome softer grips for my bandit, (Due to a case of vibration white finger)unfortunatly all the aftermarket grips I have seen don't fit Suzukis properly as in their wisdom, on the throttle side, the OEM grip clips over a raised lip on the throttle "tube"(hard to explain in words).Anyone with a suzuki know what I am talking about and found any suitable replacement grips.cheersStuart Quote
Guest Posted May 1, 2007 Posted May 1, 2007 Have you fitted renthalls by any chance common problem with vibration,one idea i was told was to fill the bars with lead shot Fishing wieghts) try it then you could fit proper Suzuki grips or have you tried Banditmania they do grips that look like they have the lip you are talking abouthttp://www.banditmania.co.uk/Custom%20Goodies/GRIPS.jpg Quote
Hot_Stu Posted May 1, 2007 Author Posted May 1, 2007 tried renthals, could not get on with them, they hurt my shoulder and neck (legacy of old car accident .. black cab 1 : mini cooper 0) Quote
Stu Posted May 1, 2007 Posted May 1, 2007 you need heavier bar end weights or fill the bars with lead Quote
