So, my clutch biting point seems to very high.
Really only bites when the lever is pretty much fully released.
Is this normal or is my cable needing adjusted.
I just feel as if its a very high biting point.
on some times it can be very normal.
Best try and adjust the clutch cable, aslong as there is no slipping on engagement..
Is it fully engaged? If it isn't it will slip and also let off a burning stink in some cases.
Mine was out, you can adjust it. Use the screw adjuster, make sure you have a little bit of free play!
if you have around 5mm of play at the lever then the adjustment is fine
if the lever is none adjustable ie it doesnt have a span adjuster then see if you can get one to fit :)
