Guest Posted October 9, 2013 Posted October 9, 2013 i have a 150 ot 200cc quad, i tried jump starting it with the plug out and it started sparking then stopped, everytime i let go of the starter then when i press it again it sparks a few times the stoppes, can someone please help me diagnose the problem Quote
Tango Posted October 9, 2013 Posted October 9, 2013 Sounds like either the coil is breaking down.....or you've got a bad connection somewhere in the ignition circuit.......or a duff spark plug?........or the crank sensor is failing or not set correctly...... Quote
Guest Posted October 9, 2013 Posted October 9, 2013 well it was running fine but i put the coil on a bike to try to get another engine started??????so i would say the crank sensor is set properly Quote
