Guest Posted October 23, 2013 Posted October 23, 2013 My lights have stopped working both my dimmed headlight and my full beam. My dipped light stopped working yesterday and the full beam today but other bulbs are still working (top bulbs/ LED's)If someone could help me with this asap would be great as I will be leaving work in the dark and kind of need my lights. Quote
Tango Posted October 23, 2013 Posted October 23, 2013 The first thing would be to check the bulbs, this is the most likely thing. Then check the fuses, but I think that the fuses will supply other things and not just the headlamps, so if all other electrical items are working I'd think it's unlikely to be a fuse. Check the connectors to the headlamps and maybe unplug and re plug them several times to clean the contacts. Then you'd be into the wiring which may not be a quick job.But first off check the bulbs....... Quote
eastanglianbiker Posted October 23, 2013 Posted October 23, 2013 check the headlight bulb first and replace if needs be sounds like its only the bulb blown Quote
Guest Posted October 24, 2013 Posted October 24, 2013 The first thing would be to check the bulbs, this is the most likely thing. Then check the fuses, but I think that the fuses will supply other things and not just the headlamps, so if all other electrical items are working I'd think it's unlikely to be a fuse. Check the connectors to the headlamps and maybe unplug and re plug them several times to clean the contacts. Then you'd be into the wiring which may not be a quick job.But first off check the bulbs....... Thanks for the advice I can clearly see that the dipped light is the bulb blown but I think my main beam is the fuse Quote
