Honda dylan problem
I have a honda dylan ses 125cc 2003 I was riding it today I'd go 20mph and it will make a popping noise out the exhaust so I thought I turn around and get it home the bike just cuts off and it won't start BUT when I stand next to the bike it starts but when I sit on it it won't start so I started it then sat on the bike the bike cuts off and dose not start again any ideas on this ppl
Cheers
Something under the seat getting crushed / moved when you sit on it?
Otherwise, not a clue!
:cheers:
Thanks for the reply man problem solved the coil was very wet that was the cause of the misfire's when I sat on the bike the wires were moving on the coil causing the bike to cut off so I got a bus to a hard ware store got some wd-40 and cleaned the coil and soaked it with wd-40 test drive was great
Thanks again
