Out and about the other day I noticed that the needle on the speedo has started to shake from side to side, only a little around the point it is trying to settle on. Also, the odometer and trip have stopped turning. I unscrewed the cable and it looked okay and re seated it but the problem is no better. Does anyone have any suggestions please?
you say you checked cable did you check both ends as i would say one end has broken off so undo it at wheel as well as clocks and see if it has broken if not does it tuen by hand as it should do
Thanks for the suggestions. I took the wheel end off yetsreday and it doesnt look good, so I have new one on the way.
on the plus side no milage being added :wink:
Every cloud has a silver lining :wink:
