dt lc 125 wont start
hi there i have a dt lc 125, ive changed the plug,it wants to start but it doesnt seem to be getting petrol through to the carb. can anyone help please ?
Right, firstly is it the right plug? Have you put the cap back on properly? Did it start fine before or is this a recurring problem?
A little bit more info and we might be able to help :)
Welcome to TMBF mate....pop over to the Newbies section and introduce yourself when you get a chance...... 8-)
So....if there's no fuel getting to the carb....check the fuel tap and inline fuel filter.....and make sure none of the fuel lines are kinked.....also try it with the filler cap open in case the tank breather is blocked and there's a vacuum in the tank..... 8-)
Hi thanks people for the help, i found the brass like slider in the top of carb was getting stuck, ive cleaned the whole carb in boiling water, rubbed down the slider and it seems to be great, will find out. Tomorrow thanks again , martin
