maccy Posted April 11, 2014 Posted April 11, 2014 Just as the title really, are there any tell tale signs that let you know its time for a new chain, Preferably while it is still fitted to the bike. Quote
Glorian Posted April 11, 2014 Posted April 11, 2014 Not sure how you go about tightening yours. But on mine i have to push the wheel back (Nut and bolt) and when it gets to the end i either have to change the chain or remove a link. Also if the teeth on the sprocket are worn out thats a potential sign it's getting worn. Quote
Tango Posted April 11, 2014 Posted April 11, 2014 Looking at the rear sprocket see if you can pull the chain away from the sprocket at the 3 o'clock position...if you can then the chain is worn. Also check the tension of the chain at several points.....if there's a big difference between the tightest and loosest points it'll need replacing. Oh....and also check the sideways deflection of the chain in the bottom run.....too much sideways movement is also bad..... Quote
maccy Posted April 11, 2014 Author Posted April 11, 2014 Exactly what I needed to know, cheers.When you say pull the chain away from the 3 o'clock position, should there be a bit of movement, or non at all? Currently I can pull it probably about 2mm off the rear sprocket. Quote
Tango Posted April 11, 2014 Posted April 11, 2014 A couple of mm is acceptable to me.....but no more than that. Quote
maccy Posted April 11, 2014 Author Posted April 11, 2014 Thats good, I dont have to worry yet at least.Cheers Tango Also Glorian, same method, but it no where near the end yet. Quote
Guest Posted April 12, 2014 Posted April 12, 2014 It"s knackered when you find it constantly needs adjusting. Up to that point it will hardly need any, then one day it turns into an elastic band! Quote
