Bandit are known for their soft front end,to cure it I got hagon progressive springs with new oil,I must admit the bike is now 40% stiffer and made a noticeable difference to front braking and handling of my motor,possibly the best upgrade on a bandit :-)
I recommend cjaccesories,enter FORUM10 when ordering to get 10% off
As I'm skint and couldn't afford the progressive springs which as said will make a big difference but I changed the oil to 15w and that had a great improvement at a very low cost, I've got a k6 which does have adjustment and with a little tweek here and there got it set up and added a rear shock that came up on evil bay :oops: I'm still getting the rear set up but it has inspired confidence into and out of the bends :salute: As much as the springs will make a major boost to the front end what I did certainly helped so if your a bit hard up then this also helps. Well done for the write up though it's great to have this sort of thing put out there :thumb:
John
