Adam Posted July 8, 2014 Posted July 8, 2014 Went for a ride yesterday and I noticed when I change gear there seems to be a lag in power, it's seems as though the rear end gets pulled down and springs back up only then do I get any power down. All of this happens in probably a second or two but feels like so much longer! Any ideas or am I just being stupid? Quote
Grumpy Old Git Posted July 15, 2014 Posted July 15, 2014 Could be simple throttle lag - Is the throttle adjusted correctly? Mixture right? Are you changing gear in the 'power band'? Quote
Adam Posted July 15, 2014 Author Posted July 15, 2014 Admittedly the throttle does need minor adjustment but that's only a few mm. And it's fuel injected everything standard so mixtures should be right I can't change them anyway. Brought a tyre pressure gauge as the rear doesn't feel right so hopefully that solves the problem. Quote
