Ezikkiel Posted September 1, 2014 Posted September 1, 2014 Hi all! anyone else had trouble fitting these to your visors? the actual pin-lock silicone visor was just to big for my helmet ( Carberg Ego ) yes i flattened out the visor and yes i had the pin-locks rotated to allow the biggest room but yet soon as i let the visor back to shape the pin-lock visor would fold out away from the visor so the only option i was left with was to cut the slit the pin-lock bobbin sits in to allow more silicone visor to slide through! been a right nightmare! Quote
Glorian Posted September 1, 2014 Posted September 1, 2014 Nope. Was a little awkward to fit on my Caberg V2RR But once it was on it was fine. I leave mine on all year round tbh Doesn't make it harder to see and i dont risk fogging up. Quote
Ezikkiel Posted September 1, 2014 Author Posted September 1, 2014 Yea now she is on I will just leave it on Quote
Gray Posted September 4, 2014 Posted September 4, 2014 I had a problem with the pins on my visor as they were not lined up correctly so my insert would not sit in. Had to send visor back for replacement. Fitted fine now. Check your pins are drilled ok Quote
