Guest Posted January 31, 2015 Posted January 31, 2015 The bike is a YBR 125.Basically the indicators work fine, but the flashing light you get on the dash to tell you when the indicators are one, doesn't. It's not the bulb, as I took the bulb out and replaced it with another bulb I had for the engine fault indicator, and it still didn't work. I put the bulb back where it was and it worked fine.Any suggestions? Quote
mealexme Posted January 31, 2015 Posted January 31, 2015 It'l be a connection somewhere...I'm guessing the rest of the dash lights work then? High beam etc. If not, then check the fuses, if they do then...Do you have access to a multimeter? Quote
Paul-Kent Posted January 31, 2015 Posted January 31, 2015 Would also help if you stick ya location in the profile , ya never know someone may be local and willing to lend a hand Quote
Guest Posted February 14, 2015 Posted February 14, 2015 Instead of hunting for a broken wire half way thru the wiring loom, Just strip the wires back for the dash light and connect each of them to the positives on each of the left and right front indicators.Good luck Quote
