Kawamad Posted April 14, 2015 Posted April 14, 2015 Another bike another problem but at least it isn't mine!Hi my son has a Superbyke RMX125 [Hyosung RX125 relabelled]It runs ok turn it on it idles rev the nuts off of it and it dosen't miss a beat....But once you stick it in gear and ride down the road it starts to bog down between 2nd and third,once you hit fourth it seems to run fine.We have done the following...1/ Carbs cleaned and blown out in a proper workshop!2/ Pilot screw turned in to seat and then screwed out one and a half turns.3/ Plug replaced and checked .4/ Fresh fuel used.And yes i know the obvious it's chinese yadda,yaddaConstructive comments appreciated Quote
