Phooey Posted April 14, 2015 Posted April 14, 2015 I have taken deliver of a pair of early Nissin calipers and now looking at a rebuild.First question, no doubt of many, I have removed a screw which I assumed allowed the pads pin to be removed but it turns out to be a grub screw type thing. How do I remove the pin releasing the pads and pads retaing clip?Thanks. Quote
Phooey Posted April 14, 2015 Author Posted April 14, 2015 Here are a few pics ... I think that they are self explanatory. The caliper as is Removing what I assumed would be the pad pin OK ... it's a grub screw! Hmmm ... now how does that pin and retaining spring thing come out then? Quote
Stu Posted April 14, 2015 Posted April 14, 2015 where you have taken the grub screw from there is a allen key in there Quote
Phooey Posted April 14, 2015 Author Posted April 14, 2015 No mate, no allen nut. Looks like I could drift out the pin but don't want to go bashing if it shouldn't be bashed.Nice if you do have a set of seals How much? Will be up to the cafe Sunday if you are? Quote
Stu Posted April 14, 2015 Posted April 14, 2015 where the grub screw goes in the allen key should be inside there as the pin screws in to the body I rebuilt a set of these off a 96? model blade this is what the pin looks like http://www.ebay.co.uk/itm/Suzuki-GSXR-O ... 4ae776add6I will have to pop to my lock up and see if I have the seals first if I can get there before sunday I will bring them with me Quote
Phooey Posted April 14, 2015 Author Posted April 14, 2015 Had another look ... Allen key took it out.How much for the seals mals mate I'll make sure I bring the money if you do find them. Quote
Stu Posted April 14, 2015 Posted April 14, 2015 £20 they are yours but let me double check I do have some they are new too just measure your pistons in the calipers if you get chance too pretty sure they are 34 and 30mm pistons Quote
Phooey Posted April 14, 2015 Author Posted April 14, 2015 £20 is a good price ... Looks like about 30mm and 27mm Will get the pistons out to check tomorrow but I am fairly sure on those measurements. Quote
Stu Posted April 14, 2015 Posted April 14, 2015 hmmmm well I will go check the seals and measure them anyway Quote
Phooey Posted April 14, 2015 Author Posted April 14, 2015 http://www.ebay.co.uk/itm/Honda-CBR900- ... 417c0ffac1Just looked up on ebay, Stu and I think these are the correct ones. Sizes match what I measured. Quote
Stu Posted April 14, 2015 Posted April 14, 2015 yeah there is two types the 27-30mm and the 30-34mm I need to check which ones I have I seem to think they are the larger ones! Quote
Stu Posted April 18, 2015 Posted April 18, 2015 Update I have seals they are 27 and 30mm Shall I bring them along for you? £20 they are yours Quote
Phooey Posted April 18, 2015 Author Posted April 18, 2015 Update I have seals they are 27 and 30mm Shall I bring them along for you? £20 they are yours Excellent ... do you want me to bring £20 or do a BACS transfer? You are a star, Stu. Quote
Stu Posted April 18, 2015 Posted April 18, 2015 I would prefer cash if thats ok? I get to pocket it rather than forget its gone in the bank Quote
