is that 11v resting? ie nothing on?
Yes, everything switched off.
Give me 20 mins, am going to borrow another meter. Will test again and post result.
the voltage should stay the same when connected
Just realised what a knob I am. Did not change meter to volts. tested r/r again and now reading 30v when revving engine
30v coming from a new reg/rec :shock:
thats enough to blow the bike up!!
Lol have I got it wrong again hahaha
Lol I got that on multi meters. How would you test r/r when it is all plugged in etc.
depends what you want to test?
the output?
so we already know you are getting 60v minimum in which is good
what you need to test now is the output you should have two red cables coming out of it
put the red probe to one and the black probe to the battery negative this is with all the wiring connected up if you can get in
do this for both red wires
the output?
Excellent, I will do this tomorrow and report back. Thank you Stu
suzuki's are well known for shit wiring on the charging systems
I modified mine on my TL1000s to get the full 14 volts at the battery as I was getting a lottle over 12.6v! just enough to charge it!
4 bits of wire and a few connectors saw 14v at the battery
shame your so far away I would have popped to lend a hand
suzuki's are well known for shit wiring on the chargingat systems
I modified mine on off my TL1000s to get the full 14 volts at the battery as I was getting a lottle over 12.6v! just enough to charge it!
Yes it is a big shame but that's life. Is that why I am seeing 13v at idle. Did not seem to charge if I Rev the engine.
could well be
or it could be that you have a lose connection and under vibration its not letting enough juice through!
this is why you check at the reg/rec to rule out the wiring
if there is a big drop from the reg/rec to the battery reading then you have a wiring fault
  • 4 weeks later...
Hi All,
Sorry for not replying. Family emergency etc.
Well, I have decided to join the AA just in case of breakdowns. Been riding bike for the last 3 days without any hiccups, starts first time on the button. Think it was a dodgy R/R and battery after all, will keep my fingers crossed.
Would like to thank you all for your help and advice, especially you STU.
Thanks again.
No worries :thumb:
Thanks for the update I was only thinking about this the other day :)
