fq-craigus Posted June 15, 2015 Posted June 15, 2015 Anyone know much about these? I want to know if i fit one will my gear indicator always display 5th gear unless in nuetral? If thats the case ill give it a miss.Second question is where to buy from? And third is, has anyone made one? Im handy with a sodering iron and can get hold of the plugs..... Quote
Dav3y Posted June 16, 2015 Posted June 16, 2015 Quite possibly a dumb question but what's a TRE ? Quote
fq-craigus Posted June 16, 2015 Author Posted June 16, 2015 Timing retard eliminator. Suzuki's retard the timing in first 4 gears to limit torque for some reason, so a tre tricks the bike into thinking its in 5th all the time so you get max torque at lower rpm Quote
Stu Posted June 16, 2015 Posted June 16, 2015 These cost pennies to make but will show as though the bike is in 5th all the time Is your gear indicator built in to the dash? Check these guys out http://www.healtech-electronics.com Quote
