Guest Posted October 23, 2015 Posted October 23, 2015 Hi all, I have just taken the rear wheel off my Hyosung 250 to change the tyre, no problem there but there are different sized spacers, one longer than the other. I just need to know which one goes on sprocket side and which one on disc side???? Quote
Stu Posted October 23, 2015 Posted October 23, 2015 Pics would help Although it's usually pretty evident when you put it together If it's all miss aligned then they are wrong Quote
oldie59 Posted October 23, 2015 Posted October 23, 2015 Always take photo's before taking something apart for the first time, and lay the parts out in the order you take them off. When removing wheels, put the spacers and any other parts back onto the spindle as you remove them and replace the nut so that the parts can't fall off.Also when removing parts such as brake callipers or even cylinder heads where there are different size bolts make a simple cardboard template and put the bolts into it as you take them off, this will ensure you put them all back in the right order. It is also a good idea to refit the bolts when possible into the frame/engine so they don't get lost. Quote
